Most of the cruisers in the Tropics that use Cetol in the end are not real happy with it. If it gets just a little away from you then you have a huge job ahead and fixing spots is a PITA as well as it is actually more work then the varnish we use. Honey Teak can be put on wet on wet and we only do that once per year here. Although Cetol can be applied as multiple coats it is a two or three times a year process.
Go Slow
Sail Far
Stay Long
