Different approach
If you draw 6-1/2 feet I presume you don't fit under the Cape May bridge. If that is the case skip Cape May and anchor behind the inner breakwater at Cape Henlopen. Get underway with the current tomorrow morning and as long as you can maintain 6 kts through the water you should be able to anchor in Worton Creek shortly after dark. Entrance is easy and you can anchor anywhere. Worton Creek to Annapolis is an easy day sail on Sunday or Monday. Please feel free to holler if you need local support in Annapolis.
