"Re bonding, the guy says he has checked all of his connections, but I wonder if he has made the simplest measurement of all: disconnect the mast bond and measure the resistance from the disconnected bonding terminal back to battery negative. It should be a dead short (zero ohms). If it isn't, then he has either a frayed or broken ground wire or corrosion in a connection."
