And it's a fast process if you're used to it and the equipment is available. If you strip your boom yourself, etc, loosen turnbuckles, mine is lifted out of the boat and safely onto horses in 10 to 15 minutes. Done.
The reverse takes another 5 or so minutes. But it's pulled with a large boom attached to the travelift. The amount of time it takes is more than recovered in covering the boat. It's not free, unfortunately. But it is a safe and stressfree method.
