You guys down south with all that unfrozen water probably can't relate.............Les has some first rate examples, Tom Young has his new cockpit project......(both would scare the bejabbers out of me). There are other maintenance things that need to be taken care of though.
The annual palm tree rehab project is on the mid-winter to do list. The key is to use black zipties instead of clear. Clear has no dye so gets eaten alive by the UV light.
