Well speed and depth shouldn't be all that much...
Wind can be expensive since they have to pull new wires down the mast. The instruments could be expensive if they have different cut out sizes from what is there and glass work is required. The autopilot install shouldn't be that bad. The expensive part will be putting the arm on the rudder post and installing the ram. Most likely that ram installation will require glass work up in the lazarette, which can take time = $$$$$.
