For us it depends on distance to travel.
We vary according to distance needed to travel. If the landfall and the destination is planned before dark we accept whatever speed will get us there in a timely fashion although anything below 3 knots is generally considered engine time. The only variable to that would be when we only have around 5 miles to go and time to do it in. We can spend the day starting the engine a number of times for a short time shutting it down when the wind cooperates.
If we have 50 miles to go it just seems dumb to travel at 3 knots when we can go 7. We purchased our vessel not as a sailboat but more of a vessel that gets us to a destination (preferribly) under wind power but the engine as a means to the destination has equal importance. Quite often we will motor till time and distance works and then sail at whatever speed the Earth gives us even if it's 2 knots although I generally feel anything less than 4 is slower than I wish for.
On a multi day passage as long as we're going over 3 we take it saving the fuel for less than that speed
Of course, a short day sail is out of those parameters. On day sails it's about comfort. If the seas are comfortable at 3 knots and we don't have a destination except for 'out & in' 3 knots or even 2 1/2 can be a wonderful speed. Less than 2 is generally agonizing.
Sailing and boat speed is a complicated concept or equation for us.
