I set the battens with the "batten stuffer" that comes with the sail. But I haven't used the sail enough to consider resetting the batten tension. In these shots, I set the down hauled tension lightly before leaving, and never re-set it that day. I was thinking too much halyard tension caused the creases. Lots to experiment with. Thanks a lot.
