Not quite. But it's better. Strangely, the feed coming from the starting battery - alternator line, is yellow. Upgrading the Amp gauges will be easy now(but I'm moving onto the next-I'm running out of time). This panel will pull forward and rest on the bridgedeck to work on.
The switches are all wired for lights (their fused lines are clipped and waiting on the boat for connectors). The panel is ready to connect a few terminals, and done.
Plus the 12V recepatacle is wired in the fused instrument circuit(blue).
