Thanks. The best part of this project, is what goes away. Here's the old panel hole and wire chase.
In Response To: NICE! ()
All the running light circuits come from the starboard side. That's the back of the old distribution panel. The engine wiring harness all comes through a chase to port. Before, 20' of harness was coiled up and tied below and behind the panel. With that removed there is much better space to run - tie and organize wires (they need to be untangled!) now and in the future.
Plus this shows the problems with the old cockpit. I was able to pull those decking pieces up with my hand. And the well has rotted in all the corners. It's gone. All this comes out in a couple weeks and will open up this whole area to clean it up - sort it out - and lower the new cockpit in.
