Return to Index
Read Responses
BTW no CPA or TCPA
In Response To:
B&G Zeus -- I finally got it ALL working
because it's moving away from me.
If you have a Lowrance CP and Broadband Radar
Larry, what do you have at the top of your mast?
Not sure I understand the question Nat
Which I do...
Judging from documentation
Folks on SA not impressed.
comes with power cable
And the video, aka NMEA 0183, cable, too.
Re: Folks on SA not impressed.
Must need feed from instruments
B&G Zeuss Touch 7"
Re: B&G Zeuss Touch 7"
Hmmm
Re: Hmmm
Just a thought...
I think it's hardware
SO WHAT DID Lowrance say? Curious minds would like to know ;^)))
Re: SO WHAT DID Lowrance say? Curious minds would like to know ;^)))
Can you get wi-fi? Skype is cheaper.
Kudos to Stephan and Defender (again)
I called B&G support today
The old B&G Hydra (18 years) used only NEMA 0183. NEMA 2000 didn't exist then. NO problem with data
All sounds good! I'm filing these for reference when I wire mine up.
Forgot to mention
Re: B&G Zeus -- I finally got it ALL working
BTW no CPA or TCPA
Do you have the Ray data there for the fancy sailing tools?
Yes it's all there
Just sold my HDS7 on eBay
That's amazing!
Re: That's amazing!
Look forward to trying mine out
Re: B&G Zeus -- I finally got it ALL working. Not here yet!
Re: B&G Zeus -- Will try to help
Re: B&G Zeus -- looks reasonable.
Re: B&G Zeus -- trim strips, check.
It's not wired backwards
Re: It's not wired backwards. If it says the green is the center pin, 8, ...
I think the issue is your cable
Re: I think the issue is your cable. Which is what I was saying, perhaps cryptically.
Triangles
Re: Triangles
Settings on Page 76 of manual
Correction, page 75. 76 is about AIS SART (really cool)
AIS beacons
Re: AIS beacons - compared
Re: AIS SART (really cool) is a great idea.
Box around your boat
Re: B&G Zeus trim strips
If it's like the H5000, you remove the covers from the sides,
Though it was kind of industrial chic.
Mine replaces an HDS7 also
I tried the B&G Zeuss Touch 7" on the water yesterday
Did you look at the B&G Zues2
Re: Did you look at the B&G Zues2
