Re: It's not wired backwards. If it says the green is the center pin, 8, ...
In Response To: It's not wired backwards ()
And the wire to pin 8 is orange, I call it backwards! Especially when orange is supposed to be pin 7, which has the green wire. The HDS works as expected; the Zeus needs the colors flipped. It's all Greek...
