As you can see, most of the rental moorings (west of the piers) and all of the anchorage would be exposed to a long fetch of CC Bay to the ESE. It wouldn't be comfortable at all, unless you moved all the way out behind the hook (labeled Long Point on the charts) beyond the CG cutter in the distance, in which case you'd have a long and rough dinghy ride to P-town.
