Return to Index
Read Responses
Voyager 26 - I made it as much like a PSC as possible.
In Response To:
Ron, nice interior... what is your boat?
the ever unpopular generator
The Honda is a 800 watt
Most Cruisers here
Craig I feel your pain
Thanks and sound
Further thoughts about solar
Generator noise
Yes I've seen/heard that too
Keep in mind that folks find slapping halyards annoying...
Yes I have considered that
Yeah, if you're going to run your engine or generator in a quiet anchorage, expect the worst.
Generator
I suppose it's too late to consider block ice Craig.
We managed....
What is your "very good insulation?"
Super Insulation...
I wondered about putting vacuum panels in pour in place foam...
Yep...
I see you used the rotozip and cut out your installed unit...
Good luck!
Ice
For the last 25 years we have made do with block ice on our small cruisers
The block ice quality around here is awful -- full of air!
Ice
You can still get the 50 pounders in Camden, with a rope handle frozen in the block.
Ice
My 2 cents ...
One more thing I use ...
My thoughts
