Return to Index
Read Responses
The Doctor has spoken
In Response To:
Actually the amount of air in the tank is a big factor..
diesel fuel stabilizer?
I just use Biobor
Ditto on the Biobor ... also use ...
Ditto Larry
The myths and mysticisms of 'topping off' fuel tanks
Don't know what to think
I fill my 80 gallon tank in the fall, for the return on my investment. It's always paid a dividend in the spring. .
My understanding of the process includes missing points in your argument
That's my understanding: water comes from condensation, condensation comes from "breathing".
If you really want to solve the problem
The amount of air in the tank has nothing to do with this
But what about condensation on tank walls?
The only effect ...
What can I say...
Hang on here for a moment ....
I agree with removing oil for long term storage
Technical discussion?
I understood it in the terms written, I'm just a boat owner....
It is an end part of many Italian meals involving (olive) oil and water?
I have a 275-gallon fuel tank outside my house
"The only way to stop this water uptake is to have a vacuum rated tank (damn expensive)". Well, not really.
Was being facetious....
yep....
A couple of comments...
The decanter was emptied into a mason jar..
Well, your home heating oil tank...
Our 275 gallon tank....
Probably pretty much past due to replace it then
Beyond what Todd observed
So, uh, do you add biocide year after year...
I checked more thoughly with our chief engineer. There's more to it, than just adding biocide after inspection.
I think you nailed it. I spent many a
Depends on how big your tank is...
Extensive testing by Practical Sailor
With my 40 gallon tank
I guess its cheap peace of mind to add it
I add only a fuel conditioner every 40 gallons or so, in my 80 gallon tank.
As (per DougR below and as) Practical Sailor clearly outlined:
Tank Access
first -- don't go using a saw with a fuel tank that hasn't been steam cleaned
Well, you really can do it safely if you
what I was thinking was not the tank
camera?
good idea Larry
Are you having a problem with the fuel/tank, Craig?(maybe I missed something)
not the tank
I wouldn't bother with the fuel gauge...
oh fine, be logical
check your ground connections
