Return to Index
Read Responses
Who built your sail,Paul?
In Response To:
No, he just asked if I wanted full battens
I've never sailed a boat with Lazy Jacks. What do I need to know?
well..
if you decide to buy
Will your new sail have battens?
Look at the simple, inexpensive, effective Harken kit.
The price at Defender has gone up a lot in 20 plus years!
EZ-JAX
Always had a problem with mine.
Oops, saw that only your top batten was full
My system.
I sailed for years without lazy jacks on my boat, only got around to rigging them last year...
ditch the blocks.
Good case for my battenless Main.
I still like to have the option of hoisting the main with the jacks deployed...
I always hoist with the jacks deployed
That's funny because I hardly ever
I usually stow one side before raising.
As my dad used to say ...
Your dad was right. You have to know when to stop designing, and start mocking things up.
I was never good at either.
diagram
The only thing I might add to the rest
This info is a huge help. Several mistakes have been averted,
So what details will change?
I'll attach blocks to the spreaders instead of the mast.
Blocks on spreaders sounds good, But...
that might be wise.
How much weight/force are we talking about?
If you have a topping lift
I do have a topping lift that will surely remain.
Too bad. Our Garhauer ridgid was a wonderful addition
I've never seen one mounted on a wood spar.
AHHHHH! $$$$$
I don't know. Mine is SS and I don't think
You could also add...
Low load
Agree with Al S, Steve and Jon E with one exception
Been through a few iterations...
PS. Here is a link to these little blocks...
I've never had a problem with chafe
I made mine from 3/16" Sta-Set
Tom: Is you main going to be loose footed?
Not at this point. The sail is not yet started,
My new mainsail with full battens works fine with the original bronze mast track.
That's interesting, Paul. My sailmaker thinks I'll have problems.
Jan Pedersen at Bayview Rigging and Sails
Glad you chimed in, Paul. I think I'm going full batten.
You'll love the full battens with all the light air sailing you do.
I'm really looking forward to it. Thanks for the help, Paul.
I don't know what the big deal with fully battenes mains are? I've
There is a big safety advantage
That's a good and very well established point.
I think that they a set-up where you can use a batt slide on a conventional track.
I always regretted not getting the main I wanted
+1 on the full battens
The sail shape is better. I don't see why not?
I have to start from scratch rigging a reefing system.
In that case, why wouldn't you use the loose footed main?
Habit?
Yes, it's moved from rain to sleet to snow...but back to booms
I like a loose footed main
I just noticed I had a reef in the main
Am I loosing my memory? I though we
Left Ft. Lauderdale for Ca. in early 2005. Left Ca. with the HaHa in 2007
I'm looking into it and have asked the sail maker what he thinks with my boom.
Answer; "There is no downside to a loose footed main".
What about the classic look?
He did this main on a friends 60's Aage Neilsen.
Here's a closer photo.
That loose material looks wrong
One possible downside
Outhaul with big mechanical advantage.
Going loose foot.
We have a spectra strap (with velcro laminated)
Do you guys have pics? I don't understand what you're describing.
The outhaul pull the sail back; and, a strop keeps the clew close to the boom (i.e., not rising up)
Good use of the word.
I have won't to able to us another word...
Ditto, works great and is as simple as it gets.
Tom won't need a strap for the clew
Stowing the lazy jacks and the mainsail cover
Dutchman
DIY Lazy Jacks
