Outhaul with big mechanical advantage.
In Response To: One possible downside ()
You need a really good outhaul set up with plenty of mechanical advantage for a loose footed main. The force on the clew is substantial and friction from side loading on the car high. At least a 4-1 purchase for the outhaul would be minimum and and a cascaded setup with 8-1 even better. Make sure you can get the end caps off the boom to beef up the outhaul tackle if it's internal.
