Return to Index
Read Responses
Heh, did I mention it's two days to Ilwaco from Portland?
In Response To:
Yabbut...it's nearly thirty hours to get to Neah Bay from Ilwaco....
Daily coastal cruising mileage
Coastal Cruising
mileage
I you stil have you Choey Lee 35
"the vacation is where you are"
All valid points! We are planning
You should be able to make 6+ knots in a 35
Work like hell at first....
One trick I've often used is to sneak some miles in before anyone is awake.
Sailing
I've enjoyed that too Peter, but this is a we question.
I know all about the we years Tom
No wonder you're enjoying your 12 hour sails.
You have called that correctly Tom!
Yeah the only problem with those morning miles
I don't mind motoring and we can usually use a few amps in the early morning.
Agreed. When aboard my wife and I get up with the sun anyway
I'd rather listen to the engine
You east coasters got it mighty damn good!
Depends which west coast you mean, Westcoaster
which is why I never figured out ...
My 'pinion don't vary.
Yup, Oregon does suck for sailing
Heh, at least in Hood River you get some better winds.
up, that's what I mean...this west coast is great for coastal cruising because we're already here!
Think 5kts.
Agree with Braden, we figure on a 5 knot average if we want to make tracks
We "plan" based on 5 knots too. That leaves us in a frame of mind to sail if the wind is light.
What is the least wind speed for you to keep up 5 knots, Larry?
Depends on a lot of things, but optimally we need about 3-4 knots true wind to sail 5 knots.
Further about the above post -- I really don't know the numbers
That's a very cool boat, Larry.
With the family we try not to sail more than about 5 hours between harbors
That's the honest approach!
The track you're on there is the text book "should we go overnight?" for a sailboat.
Hi Braden, that's good advice!
I call them splits
Thanks Dan. I think
Ah, that's the joy of no wind and a good engine... a civilized breakfast. I can smell it now.
Mornin' Braden! I'm not sure I'd ever
Depends totally on the wind...
Thanks for all the help!
