safest and most easily navigated in just about anything. Probably the best and most straightforward Cut in all the Exumas. No problem ... even at night !
I doubt there is anything less than 8 feet of water between Little Farmers and Galliot, at short tide. And even though the Explorer Charts say differently, you can go all the way from Galliot to Rudder Cay Cut over the Bank as well. Beautiful, perfect little anchorage just north of Rudder Cut, no current. Believe it or not, that little anchorage behind Musha Cay is a good all-around anchorage because the flats to the west dry and no fetch ... can be Windy, but you'll be calm in a Front as the wind swings around.
Cheers, John
