Return to Index
Read Responses
LOL! I see have have few sympatico's
In Response To:
The mechniacal and electrical things you "should" be alble to do only depends on your sailing area.
A quick survey - How much maintainence/repair work on your boat should you be able to do yourself?
If by ''component" you mean....
I draw the line on engine work at the
I did mean "box"...
A cruising friend did almost nothing himself
It's mostly
Ideally I agree with you
lol- having JUST done a bottom job, including all the sanding, at my age NEXT time
Exactly. The things I no longer want to do!
ROFL- Braden- I'll be 73 next month. Keep on keeping on-grin
You give me hope.
everything but electronics and sail making
DYI
#4, great point.
Why should anyone have to be able to do 100% of their own boat maintenance, if they can't or don't want to?
I'm with Tom …
Being able to vice making a choice not to are two different things.
People may laugh, but 'hring it out' well, is a learned skill too.
Everything but electronic repair, crane work, and machining.
Where the job sits on the skill/labor spectrum counts
Work aboard and age....
almost everything
More than half the reason I have boats is that I enjoy working on them..
Todd do you have a yard or barn that allows you to work on your boat?
I have plenty of space to work on my boats...
Then I agree, if you enjoy working on them more than using them, you should do 100% of the work.
maintenace/repairs
Almost everything
Well, did it all 'back in the day'. Not now.
Yeah, yeah. I'm waiting, bring Jaunty on- we'll go catch a Spec or three
This is the winter for it.
I was thinking 'changing the fuse' was overkill.
I do have some Kryptonian tools that Jon said i must have.
IT DEPENDS
Agree. And then there is the age old paradox..when you have time, you often do not have money, and vice versa.
Absolutely it depends...
Have done everything except fixing electronics, but
I do nearly everything myself - not because I want to....
When you are itinerant like us, there is
Sounds familiar
I think you shoud be able to do what will get you homel
I do most things....
