The electric will go on the power boat....
I went with a 22 lb delta anchor so it will self launch. Since it is a power boat I figure I should be able to cruise into an anchorage, push the anchor down switch, then break out a cold one just like all the other power boaters :)
The 700 is fine for that anchor with 1/4" HT chain.
