the hydraulic wheel steering that the boat came with turned out to be too unreliable and problematic (unless I replaced the helmp pump, which is an expensive proposition), so converting to a tiller was a no-brainer solution. (Removing the binnacle in the cockpit also had the huge benefit of freeing up a ton of space there, allowing me to build in a propane locker to hold two 20-lb. cylinders.
