You see the islands on the chart and put the cursor on them to see how far off they are. Without realizing that you have done it you set a waypoint there. Then you set you way point to the final destination and iterface with the autopilot. The result isn't good.
A few years ago a boat sailing in this area used an offshore island as a waypoint and ended on on the rocks there while the crew was below for lunch.
