We have a Vetus (I think) flap on our engine discharge
In Response To: Thru Hull Question Hydro lock? ()
Our stern is "square" to axis of the boat, but I think with your canoe stern you would get adequate rear pressure.
As Brian says, it usually isn't an issue with a proper installation; however, if you want to be sure, look into those flaps.
