You want a "modern" unit that won't flash off while switching from 1-Both-2 because you can fry your alternator's diode(s);
The DC panel breaker has different purposes -- I'm not sure it should be as low as 50 amps at 12 volts, even though you don't tend to draw that much. Do you have an inverter?
I'm not sure if you have another engine starter battery, but that's another issue that you'd need to protect (you dont' want to be powering your starter from a 50 amp breaker.
Your batteries, if something happens with a short will doing all kinds of things to one another and the connections betwen them and the gound.
If you have a distance issue, use a properly sized fuse between the batteries, the beefy cables needed, and the switch(es).
Don't you have a Sabre?
