Return to Index
Read Responses
Wow! Catastrophic.
In Response To:
I've dodged a lot of bullets myself, but this one hit me right between the eyes.
That must have ended your sailing season early. I feel for you.
Battery selector switch idea.
Safety switch?
David, perhaps I can clarify
Does your panel have....
Yes Brian a master breaker is what I am installing
Can you relocate your switch?
I could but
As Brian and others have suggested, proper disconnect is really the way to go.
I must be missing something?
You had a disconnect 1-both-2 or off?
Yes that is correct
You should, beyond a fuse, be able to kill the power delivered from the batteries to ALL devices downstream
SG thank you for your input
Does it disconnect the batteries from the engine and everything else?
How much is the blue seas breaker and box?
You could draw a multiple of 50 Amps momentarily to start the engine
All devices... what about bilge pump?
A fuse that is above the cockpit sole would be a good idea.
I have a direct wired BP, and it has drained a battery, more than once.
Good point on the short cycling drawing things down.
Mechanical Bilge Pump Switches SUCK! IMHO
Main problem is...
Well, that's something I never thought about but
I have had success with the Witch electronic switch....
Gene, I would install a switch and a fuse
Alarm and counter too...
Yes, definately an alarm. When things are going
In the end, not much will save you if the 'hole' is beyond an inch or so.
Yes... I've noticed that when swaping out the speedo impeller...
You're probibly right. I'm an advocate of
Repairing the rudder
Aftermath, Benny and Ann. We were
Great story! We had time to power 3000 feet, then the motor went under water.
That kind of stuff makes MEN!
Truly, it's
I was going to ask you but hit enter to soon. How
Wow! Catastrophic.
Oh... That would spoil your entire day!
Aftermath, Benny and Ann. We were all
Later, me on the left helping Benny
I look at a counter as a necessity
An audible alarm works for me...
Shower water into the bilge?
My previous owner actually drilled a hole in the shower pan
Mine has a drain...
Brian, I suppos that if you didn't live aboard and having two of us shower
I hear ya...
So you shunned being a dirt dweller as well.
We are dirt dwellers now...
Tried several alternatives...
boat is a Coast 34
