Return to Index
Read Responses
But you guys still carry Interlux stain filler?
In Response To:
Tom, Pettit has discontinued all of those...
Planning a new cockpit this winter, Teak is $30.00 per board foot.
In addition to epoxy...
Good idea on the cloth.
I think the other pictures you posted show the teak on a "box lid" or "box"
One method I learned(which I may use) is to fasten the strips with pan head screws, in epoxy.
Tom, I installed the "Gougeon Bros." 1/8" teak deck on Passage and after a few years....
I plan to only use traditional seam compounds, Westy.
Teak strips with the wider bonding area adhered well.
Everyone I know says the caulk from Teak Decking Systems is the best.
It uses black deck caulk
Sounds like a similar technique used at Camper & Nicholsons & no doubt elsewhere
Ah, now I get it. Weights, clamps, screws, lots of methods.
Vacuum bagging would be the best way to glue the new sole down.
I'll see if any of my friends own one.
Re: Planning a new cockpit this winter, Teak is $30.00 per board foot.
Nice work, Ken. I'm open to anything.
Get a copy of Fred P. Bingham's "Practical Yacht Joinery".
Was going to suggest Ipe. I've used it a good bit as a replacement for Teak Works well, but hard.
How does IPE compare in looks to teak?
Left alone -- it gets VERY grey
Interesting. So what's your professional opinion of using it in this manner for decking?
Ipe is now pretty much THE wood used on docks as decking. ALL of trhe docks in my
You're a woodworker...
Pouring here now- remains of Patricia. Tides 4 ft above norms. But when I can, I'll try something-
Left alone to weather, VERY closely. Varnished, almost a match.Hard to tell apart
Re: How does IPE compare in looks to teak?
Take a look at this pic. The trim across the front of the settee is Ipe. All else is teak
Another detail; the locker top drain scuppers.
2" Ipe delivered-- $9.50.
Here's a teak deck close up.
I've always favored the end grain being trimmed and mitered cornered.
I used some Ipe in my rebuild of Tortuga....
When Tortuga is on the hard, do you call it Dry Tortuga?
I do intend to start using the Petit fillers.
May make the boat feel a lot smaller inside the cabin?
Only on the exterior bright, Steve. I don't do much with the interior. It's out of the sun.
Yes...
I have been using the dark mahogany
Our Deck Is Red Meranti
My .02 on Ipe
