The stripper and hause pipe and other configuration issues are factors. Our Lewmar Ocean winch with 3/8" HT Chain and 3/4" three strand seems to feed "okay" -- but I really think that you should count on it feeding back in unattended with confidence. The problem, if you can't see what's going on, is that you can get the whole system jammed-up in the stripper or hause pipe. I really think that an all chain is the way to go if you want to count on it to retract on a dark and stormy -- or in a blow.
