Something ain't right. either the hawse hole is too small or the splice is too fat. Also check your pressure/control arm
if you have one. A properly installed rope/chain windlass with a properly done rope/chain splice rarely if never hangs up. Also, make sure you have enough fall distance below the windlass.
