Return to Index
Read Responses
Gene, The number you gave me doesn't seem to work.
In Response To:
See, there in lies the question
Is there another?
Well still no joy with the engine. Yanmar 2GM20F
Gene, have you checked the compression?
What I am thinking is something failed...
Have you checked the fuel tank vent?
That was....
try this email
I replied with a number.
Steve, where are you?
Downtown SD
Are you on the transient moorings or in a slip?
I am heading down to the boat.
Did you bleed at the injectors?
Yes I did.
Good decision to call an engine guy, Gene.
Agreed. There comes a time when you give the problem to a professional.
That's normal for the clicker.
It is that latter that I am hoping for...
pump lever
ah, but I have rotated the engine several times...
Often, the 2GM20...
Ron, Greg Dlezynski suggested nearly the same thing.
Gene, that particular...
I have raw water turned off.
One last little caviat...
Will check. Just removed exaust elbow.
I MAY HAVE FOUND THE PROBLEM!!!
GOOD ON YOU Gene!
A mixing elbow is one of our major spares...
I can pretty much guarantee you...
Took the mixing elbow over to a friends house....
Some suggestions
There does come a time...
(Message Deleted by Poster)
By the way...you will probably never get them apart
That makes sense
oops, didn't mean to delete.. was going to edit above
So I went ahead and ordered all spares...
Is there a diameter change?
The threads in the mixing elbow are reversed.
I hate when people do that.
I never tried to take that end apart.
How about....
Makes sense where I want the parts to come apart...
You might give
Will do.
I agree!
Start it and see if it runs.
Was tempted Rich...
I made one out of bronze water pipe parts
exhaust
that water vent is a good idea
This, from my basement, may look familiar.
Well it is the exhaust elbow and the mixing elbow...
that is like mine
That's a strange looking mixing elbow.
Look at the built up one again.
Got it. Understand how it works but it still looks a bit strange to me.
Here is a pic of the new mixing elbow... looking inside.
Would be nice to get those ports polished. Mebbe not build up as much over time.
Yeah, new is a good choice on that piece.
Yes, it looks like...
I think you are right on that Brian...
