Return to Index
Read Responses
that water vent is a good idea
In Response To:
exhaust
I have that too. You can tell immediately if the water is not right.
rich
Well still no joy with the engine. Yanmar 2GM20F
Gene, have you checked the compression?
What I am thinking is something failed...
Have you checked the fuel tank vent?
That was....
See, there in lies the question
Gene, The number you gave me doesn't seem to work.
try this email
I replied with a number.
Steve, where are you?
Downtown SD
Are you on the transient moorings or in a slip?
I am heading down to the boat.
Did you bleed at the injectors?
Yes I did.
Good decision to call an engine guy, Gene.
Agreed. There comes a time when you give the problem to a professional.
That's normal for the clicker.
It is that latter that I am hoping for...
pump lever
ah, but I have rotated the engine several times...
Often, the 2GM20...
Ron, Greg Dlezynski suggested nearly the same thing.
Gene, that particular...
I have raw water turned off.
One last little caviat...
Will check. Just removed exaust elbow.
I MAY HAVE FOUND THE PROBLEM!!!
GOOD ON YOU Gene!
A mixing elbow is one of our major spares...
I can pretty much guarantee you...
Took the mixing elbow over to a friends house....
Some suggestions
There does come a time...
(Message Deleted by Poster)
By the way...you will probably never get them apart
That makes sense
oops, didn't mean to delete.. was going to edit above
So I went ahead and ordered all spares...
Is there a diameter change?
The threads in the mixing elbow are reversed.
I hate when people do that.
I never tried to take that end apart.
How about....
Makes sense where I want the parts to come apart...
You might give
Will do.
I agree!
Start it and see if it runs.
Was tempted Rich...
I made one out of bronze water pipe parts
exhaust
This, from my basement, may look familiar.
Well it is the exhaust elbow and the mixing elbow...
that is like mine
That's a strange looking mixing elbow.
Look at the built up one again.
Got it. Understand how it works but it still looks a bit strange to me.
Here is a pic of the new mixing elbow... looking inside.
Would be nice to get those ports polished. Mebbe not build up as much over time.
Yeah, new is a good choice on that piece.
Yes, it looks like...
I think you are right on that Brian...
