Return to Index
Read Responses
Good thought. I'll err on the deeper side. I've seen plenty of smaller channels.
In Response To:
Re: Fiberglass saves space: Is a 3/4 inch gutter going to
Many on similar boats are metal U channels that are smaller(but do they work?). Thanks.
A cockpit well.
Hoisting points
I will need some hoisting points.
Complication I have is the two big cockpit locker tops.
Are you planning to glass the entire inside of the cockpit well?
Yes I am, Todd, except the sole.
I would glass the sole...
Concur.
Ok,...you convinced me on the sole, but I can't go up the well sides.
The "modern" approach would be to have a gutter below the lids which drains out into the cockpit.
That is what I'm doing.
Sounds like a good plan. As regards the hinge side gutters others must have solved this previously.
Pondering hinge side...seems my memory conures up the usual.....
Here's a rough sketch in actual size of my plan.
I think the gutters are too narrow, Tom.
Fiberglass saves space, I need the wood structure around the gutter.
why not build fiberglass locker lids....
That sounds like more than I want to learn about fiberglassing.
To make the glass work easy...
Set time on polyester is more of a curse than a benefit...
And that time helped. All done and a fill coat on.
Nice work
In the end, I turned up the heat and got a second fill coat on.
UV and staining resistance?
I haven't had a problem with poly going off before I was done...
Deeper gutter means better beam support? I'd think so.
Looks about right to me. Couple things I notice......idle curiosity.
Tom, bear in mind all those trim and joining pieces are there to deal with end grain exposure.
Good thought ,thanks. I see miter margin joints both epoxy glued or caulked.
Re: Good thought ,thanks. I see miter margin joints both epoxy glued or caulked.
True but look closely at that newer boat.
Here's one I like with glued miters and a few other simple details...
You disappoint me, Tom
I love those, Paul!
Re: I love those, Paul! So do I. They fold and hang against a wall totally out of the way. I did add
I figured you were fellow of the build your own from shop scrap school
