If you want more time catalyze at 1%. Also the easiest way to do a flat surface is to cut out the fabric. Then using a paint roller, roll a coat of resin on the surface, put the fabric on, roll resin into it then air roll it (air rolling is not needed with a single layer of cloth). You could easily do everything in Tom's pic below in 5-10 minutes after cutting the fabric.
