Drop into the lazy jacks (as we have) and then what? Let it droop? Perhaps it's a question of neatness. I would try to get the old laminate full-batten main into as decent shape as I could. With the new main in HA Dacron, it may take a while to set into a pattern. Is that really good for a sail? Jon just commented that using the same folds is worse for Dacron than laminate. I guess with the Dutchman, you really do get locked into the same folds.
