used to do it pretty much every time on smaller boats. Anomaly has a 960 sq ft main made from laminate. If you have three or four really tall crew members and flaked it carefully as you dropped it, you could probably flake it. Single handed, no way. I drop it quickly into the Stack Pack, then as time permits go forward and straighten it out as best I can, then zip the cover closed.
