If the slugs come out of the slot in the mast, the sail will flop all over the deck as they come out unless you have one and probably two or more people to flake it as it comes down. Wouldn't want to have to deal with that loose sail in a real blow. If all you do is sail inshore with a crew will work but not short handed at sea.
