They have the area. But I use the term, 'NetZero' tongue in cheek when it comes to boats. It's a bit of a gimmick in housing to start with: too expensive for the regular homeowner, so what's the sense?
But I'll refine my rant here to; 'NetZero-generator - boats'.
We can do that! You've proven you can do it running enough refrigeration, Greg does on his boat and serious cruisers like Mark do it-while living aboard, because there aren't other good options. Most of here are not too generator dependent. Is it because we're from a bygone era?
If there is an increasing trend in generator dependent coastal cruisers out there, can anything be done to reverse the trend?
