you've got the wrong lattitude
I think the number you wrote is west longitude. The latitude around Gloversville should be around 43-degrees north. Will the water keep flowing in winter? Any hydropower plans will need to allow for freeze possibilities, and ability to easily winterize or have fail-safe heating if you travel away overnight.
