I'd keep the Danforth in the cockpit locker, low and forward.
In Response To: anchor mount opinions ()
I can't imagine using two anchors often enough as a coastal sailor to justify setting up another on the bow(cruising, I might feel differently).
The weight is my main reason. The bow is an especially good place to remove weight on a sailboat.
I keep a 35lb HT Danforth-forward in the bottom of a cockpit locker along with it's chain and rode. I use it once maybe, every couple years.
