I like the interpertation of your use of the word in this case. Anchor manufacturers are always undersized in they're specs. If you purchased what they consider properly sized it would be too small. but when 'you' say properly sized, you factor that in and consider oversized as properly sized.
General feeling for cruisers is a properly sized anchor is one that's at least 1 size larger than the manufacturers suggestions.
