Return to Index
Read Responses
I've seen this done before and I liked it. It
In Response To:
Danforth on rail mount...
solved the issue of the shank swinging around and it's being to long all in one mount.
anchor mount opinions
I'd keep the Danforth in the cockpit locker, low and forward.
Yup
I'm like Tom. I have a 22 pound Claw on the bow roller,and a 12 pound Hi tensile Danforth in the cockpit locker,
Mounting Anchor on Bow Pulpit
Peter...
Some pictures of anchor brackets..
Pic 2
Pic 3
Pic 4
Pic 5
Pic 6
I have my Danforth rail mounted on the pulpit
Questions, Craig...
answers
Seems like light groud tackle to me.
Lewmar
Danforth used to make a CQR model anchor. Had a 35 pounder on my tri
Still using one as my primary anchor
You're getting your money's worth out of that relic, Paul.
That's a 35lb. and at least 20 years old
too small
Cockpit locker, 30' chain in a canvas bag for easy deployment by dinghy
Max, you should have dumped the 90 feet
Once they started chanting I couldn't give up on the effort
It's not fun to always be the audience. Sometimes
That is funny. I have rowed all my kedges out over the years.
I take it all in the dink.
I have the same set up on my Shannon PH38. What
Custom Bow Anchor Setup
Rather than play with different anchors for different bottoms,
Properly sized?
The recommendations for Rocna and Manson are "much higher"
They are not "upsized"
Not only weight, the whole profile doesn't work for me
I dispute putting a CQR & Delta in the same 'old' styele class
OK, let's call it a transitional design then
In the Bahamas, way back in the 80's,...you could often hear some guy bragging about his anchor on the vhf,...
Fatty Goodlanders latest book. Creative Anchoring
If you are serious about an anchor book
I agree Tom, but think you missed my point
It's more that your point is subjective, Mark.
Plow Anchor History
PS
Yes, everybody appreciates the boat anchored in 10' with 300' of chain out
Even more fun with 300' of nylon rode
I never said I had dismal performance with our CQR
BTW, there is one thing I really like about this BB
Good example. If new gen anchors afforded the vast improvement gps e-charting does over paper,
I don't understand that last line
I see the difference
Rare?
I'm the same. I only sleep well because I have confidence in my ground tackle.
20 knots in an open roadstead
My anchoring priorities are;#1-where, #2-how, #3 size, #4-$, #5-make.
An old friend and I were sailing off Oahu, heading for a night crossing to Kauai....
Anchoring Priorities
1 oversized anchor and use it all the time
