projects done this year. Replaced my strataglass/sunbrella enclosure with acrylic windows bonded into Stamoid fabric. The difference in clarity and appearance is very noticeable. The other project was to relocate my generator from the bridgedeck locker it was in, to my stb, aft engine room. The cooling water pump will no longer thrash itself to death trying to suck water through 20' of hose and lift it up 4' above the waterline. The sound deadening improvement was a very welcome side benefit (which I had hoped would be the case). I might even use the generator now!
