Don't forget to add...
Don't forget to add the correct controller. You'll need to set for the correct amt of amps and voltage and a place to dump any extra amps. Those Lifelines are sensitive and if you can push 16 volts Justin says you can cut your time down to "condition" to 6 hours. Also make sure you have a good windy day for airing the boat or a blower to rid yourself of the fumes.
Go Slow
Sail Far
Stay Long
