Larry - here is a crude estimate...
That isn't a lines drawing for the hull. What I need is more properly called a body plan. However, based on displacement and LWL, the crude results are:
Speed - rpms - gph
5 ----- 1660 -- 0.4
6 ----- 1960 -- 0.65
7 ----- 2120 -- 0.75
8 ----- 2420 -- 1.15
9 ----- 2720 -- 1.6
10 ---- 3020 -- 2.2
There are a lot of assumptions in this simple estimate. I didn't take the amas into consideration, so the numbers are probably about +/- 100 rpms and +/- 10-20% on the fuel consumption. If the engine rpms match reasonably closely with your results for a speed, then the fuel consumption figures are probably pretty close too
