Then why do many sailboat designers spec larger auxilary engines,...
than they need to reach hull speed? I'll ask the reverse question.
Has anyone ever felt they were underpowered in adverse conditions with a sailboat, even though they had enough power, plus some margin, to reach hull speed under benign conditions?
I bet a few people would answer yes. Don't you think?
I'll bet Larrys extra power can be put to use now and then, say in a stiff headwind and he wants to get into an inlet to windward perhaps. His boat has quite a bit of windage. Think about 30 or 40 knots on the bow for instance and you have to get somewhere. Maybe the designer took that into account.
