My Cross 35 Tri had a spade rudder. I used 1 1/2 stainless for a shaft. I also
built it with the top two inches made from foam, glassed over. Intent was that should it get bent, I could use a hand saw to cut away the top and still be able to steer. Thankfully never needed to try that out.
